National Asphalt Pavement Association
http://www.hotmix.org/
Recycled Foundry Sand is a two-part series that appeared in HMAT magazine in 2002:
- Sources and Properties
http://www.hotmix.org/images/stories/rfs1.pdf - In the Mix
http://www.hotmix.org/images/stories/rfs2.pdf
Evaluating the Use of Waste Materials in Hot Mix Asphalt: Special Report 165: NAPA, 1995.
http://www.afslibrary.com/Home/Results/Detail/tabid/55/Default.aspx?ArticleId=38831
Recycled Materials Resource Center (RMRC) Foundry Sand Portal
http://www.recycledmaterials.org/materials/fs/start.asp
RMRC Webinar: Designing Hot Mix Asphalt with Foundry Sand
- Handout version:
http://www.recycledmaterials.org/materials_docs/foundry_sands_docs/webinar/wk2_fsS_in_hma.pdf - One hour webinar session, presented October 2008:
http://epdmxgateway.engr.wisc.edu/epd/K479/K479-02.mov
Foundry Sand References: The RMRC Foundry Sand Portal contains a searchable database of journal articles and technical literature.
http://www.rmrc.unh.edu/materials/fs/references.asp
Standards and Specifications: The RMRC Foundry Sand Portal includes a searchable database of standards and specifications relating to the use of foundry sand in highway and construction applications.
http://www.rmrc.unh.edu/materials/fs/standards.asp
Note: ASTM is developing a Standard Specification for the use of Foundry Sand in Bituminous Mixtures. The standard is expected to be voted upon in 2010.
Federal Highway Administration
User Guidelines:
- Asphalt Concrete Description:
http://www.rmrc.unh.edu/tools/uguidelines/app.asp#asp - Foundry Sand in Asphalt Concrete:
http://www.rmrc.unh.edu/tools/uguidelines/fs2.asp
