Casting Source Directory
Use the Quicksearch to look up a specific company or the Advanced Search system to search for a foundry by metal, process, weight or location. This directory contains information about more than 2200 metalcasters in North America. If you aren’t sure which metalcasting process you need to produce your component, our Casting Alloy & Process Selector (CAPS) is integrated into this directory system. If you are a metalcaster and would like to update your information, click here to update online or click here for the PDF form. You can also contact Barb Jackowski, AFS Customer Service at bjackowski@afsinc.org. To purchase the print version of the Casting Source Directory, click here.
