Coldbox Process 101
Learning Outcomes
  • Explain the benefits of using the coldbox process for coremaking.
  • Explain the coldbox coremaking process.
  • Explain the components of the three most common coldbox systems.
  • Identify how sand, binder and equipment selection can impact the quality of cores.
  • Describe the important safety measures and operating practices to use while making coldbox cores.
  • Identify the key aspects of well-designed tooling.
  • Identify common coldbox-related casting defects.
Course Introduction
This course is an introduction to the coldbox coremaking process used within a metalcasting facility. Discussion will include terminology, common sands and binder systems used to make coldbox cores, the coremaking process, using and maintaining equipment, and considerations for identifying core defects.
Benefits to Taking the Course
Participants walk away with a broader knowledge of the coldbox process, gain ideas on how to more effectively utilize their current process, and explore different, perhaps unfamiliar, options for improving their process. Attendees also leave the course knowing the 12 key factors to consider when selecting a binder system.
Module 1: Introduction
Module 2: Coldbox Overview
  • Cores
  • What is Coldbox Coremaking?
  • Why Use the Coldbox Process?
Module 3: Sand
  • Sand Impacts and Types
  • Impacts of Temperature and Moisture
Module 4: Binder Systems
  • Terminology and Systems Overview
  • Phenolic Urethane Coldbox (PUCB)
  • Acrylic Epoxy Coldbox (AECB)
  • Ester-cured Alkaline Phenolic Coldbox (ECPCB)
  • Factors to Consider
Module 5: Equipment
  • Coldbox Equipment
  • Do’s and Don’ts
  • Equipment Maintenance
  • Personal Protective Equipment (PPE)
Module 6: Tooling
  • Well-designed Tooling Results
  • Case Study: Which Design is Better?
Module 7: Defects
  • Defect Causes
Module 8: Conclusion
What our students are saying............
"Very good and informative course."
"Thank you and I hope to attend the next one. Very well done."
"Great class! Hopefully I will get to do Coldbox 201."
"Very great instruction – I will be able to use what I’ve learned on a daily basis."
