Casting Material Properties
Learning Outcomes:
  • Identify and describe a variety of production characteristics that can influence the mechanical properties of a casting.
  • Identify various tests to determine a casting’s material characteristics.
  • Identify the impact the distribution of mechanical properties was on the function of the casting in service.
Course Introduction
This course provides an in-depth discussion on expected performance of a casting.  The production process influences the resulting mechanical properties and expected level of quality.  The impacts of irregularities and post casting treatments are discussed along with testing methods for determining properties and existing sources of property information that can be used in the casting’s design.
Module 1: Introduction
Module 2: Production Influence on Casting Properties
  • Cooling Rates and Heat Flow
  • Casting Irregularities that Impact Mechanical Properties
  • Post Casting Treatments
Module 3: Measuring Casting Properties
  • Test Specimen Location
  • Testing Types
Module 4: Impact of Properties on Performance
  • Properties vs. Performance
  • Simulations
  • CADS Case Studies
Module 5: Conclusion
Who Should Attend?
Those who design castings, performing casting FEMA, or performing casting property measurements.
